I have created attribute in windchill that attribute values should reflect in the xml file
Gokul_Nishanth
7-Bedrock
Hi @Gokul_Nishanth
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Can you describe the steps you have taken so far to create the attribute in Windchill and ensure its values reflect in the XML file?
  • Have you configured the attribute mapping correctly between Windchill and the XML file? Are there any specific settings or configurations you have applied?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Hi Catalina,
Thank you for your thoughtful response and for providing guidance on how to enhance my inquiry.
To clarify my current situation regarding the attribute creation in Windchill and its reflection in the XML file, here are the steps I have taken so far:
  1. Attribute Creation: I have successfully created the attribute in the textual information element wizard.
    I have referred this following article and i have worked on the burst configuration using this article
    Article - CS304852 - Configure a Burst Metadatarule using Windchill and Arbortext
    Article - CS171855 - Problems getting Windchill attributes into XML documents using Windchill PDMLink 10.1 M040 and Arbortext Editor 6.0 M120
    Article - CS104162 - How to pre-populate <twowaymetadatarule> attribute value with setting of toxml before bursting into Windchill using Arbortext Editor
  2. Attribute Mapping: I have attempted to configure the attribute mapping between Windchill and the XML file, but I am not certain if all settings are correctly applied.
  3. My goal is to map the windchill attribute values to xml file
Thank you for your assistance, and I look forward to any further advice you may have!
