avillanueva
Mar 29, 2023 7:11 PM UTC
Likely very simple question about input on wizards
I have a very simple wizard when I just need to gather a text response from the user. I followed an example but must have missed something. My attribute panel appears but not the textbox I had expected. Here is what I see:
Here is the builder code that I used:
public AttributePanelConfig buildAttributesComponentConfig(ComponentParams arg0)
			throws WTException {
		ComponentConfigFactory componentconfigfactory = getComponentConfigFactory();
		AttributePanelConfig attributeconfig = (AttributePanelConfig) componentconfigfactory.newAttributePanelConfig();
		attributeconfig.setComponentType(ComponentType.WIZARD_ATTRIBUTES_TABLE);
		JcaGroupConfig group=(JcaGroupConfig) componentconfigfactory.newGroupConfig();
		group.setId("justification");
		group.setLabel("Enter Justification");
		group.setIsGridLayout(true);
		JcaAttributeConfig attribute = (JcaAttributeConfig)componentconfigfactory.newAttributeConfig();
		attribute.setId("justification_value");
		attribute.setRequired(true);
		attribute.setLabel("Justification");
		attribute.setComponentMode(ComponentMode.EDIT);
		group.addComponent(attribute);
		attributeconfig.addComponent(group);
		return attributeconfig;
I thought that all I needed was to set the component mode to edit. I did this before with a table but in that case I used a data utility to make a editable text box. Is that what I need to do here? This should just be a simple textbox where the user can enter a short few sentences and I can pass that to a workflow.
Mar 29, 2023 8:35 PM UTC
You need to set the exact component in the buildComponentData method. There you can define if the attribute is a textbox, textarea, checkbox, dropdown, etc.
 @Override
 public ComponentConfig buildComponentConfig(ComponentParams arg0) throws WTException {
 ComponentConfigFactory factory = getComponentConfigFactory();
 AttributePanelConfig attributePanelConfig = factory.newAttributePanelConfig();
 GroupConfig groupConfig = factory.newGroupConfig("customConfig");
 groupConfig.setLabel("Input");
 groupConfig.setRenderOnTop(true);
 AttributeConfig attributeConfig2 = factory.newAttributeConfig("textArea", "Input");
 groupConfig.addComponent(attributeConfig2);
 attributePanelConfig.addComponent(groupConfig);
 return attributePanelConfig;
 @Override
 public Object buildComponentData(ComponentConfig config, ComponentParams params) throws WTException {
 Map guiMap = new HashMap();
 TextArea textarea = new TextArea();
 textarea.setName("textArea");
 textarea.setId("textArea");
 textarea.setValue(message);
 textarea.setEditable(false);
 textarea.setRichText(true);
 textarea.setEnabled(false);
 guiMap.put("textArea", textarea);
 return guiMap;
 @Override
 @Override
 return guiMap;
HelesicPetr
Mar 30, 2023 7:00 AM UTC
Hi @avillanueva @BjoernRueegg
I have more complicated solution 😄
Define own Data Utility for the attribute and you can return what component type you wish  .
@BjoernRueegg thank you for the experience.
I used buildComponentData to get objects in a table but I didn't know it is possible to use it for the AttributePanelConfig 😄
PetrH
