Hello everyone!
I try to execute a post request, but get this error:
{"error":
{"code":
"INVALID_NONCE","message":"A potential security problem was detected. Refresh the
page and try again. If the problem persists, contact your administrator."
I found this article:
https://www.ptc.com/en/support/article/CS312447
It says that a token is needed, but I already added it and still does not work.
Here is the request that I execute to get the token:
http://server/Windchill/servlet/odata/PTC/GetCSRFToken()
Here is my code for the post request:
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.Reader;
import java.io.UnsupportedEncodingException;
import java.nio.charset.Charset;
import java.nio.charset.StandardCharsets;
import org.apache.http.HttpEntity;
import org.apache.http.auth.AuthenticationException;
import org.apache.http.auth.UsernamePasswordCredentials;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.methods.CloseableHttpResponse;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.entity.StringEntity;
import org.apache.http.impl.auth.BasicScheme;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.HttpClients;
public class Post {
public static void main(String[] args) {
try (CloseableHttpClient httpClient = HttpClients.createDefault()) {
HttpPost httpPost = new HttpPost("http://server/Windchill/servlet/odata/ProdMgmt/Parts");
String json = "{\r\n" +
"\"Name\":\"TestWTPart_001\",\r\n" +
"\"AssemblyMode\": {\r\n" +
"\"Value\": \"separable\",\r\n" +
"\"Display\": \"Separable\"\r\n" +
"},\r\n" +
"\"GatheringPart\" : false,\r\n" +
"\"PhantomManufacturingPart\" : false,\r\n" +
"\"Context@odata.bind\": \"Containers('OR:wt.pdmlink.PDMLinkProduct:48507000')\",\r\n" +
"\"DefaultUnit\":\"kg\",\r\n" +
"\"DefaultTraceCode\":\"X\",\r\n" +
"\"Source\":\"buy\"\r\n" +
StringEntity jsonEntity = new StringEntity(json);
httpPost.setEntity(jsonEntity);
UsernamePasswordCredentials credentials = new UsernamePasswordCredentials("wcadmin", "123");
httpPost.setHeader(new BasicScheme().authenticate(credentials, httpPost, null));
httpPost.setHeader("Content-Type", "application/json");
httpPost.setHeader("CSRF_NONCE",
"MY-TOKEN");
CloseableHttpResponse response = httpClient.execute(httpPost);
HttpEntity entity = response.getEntity();
if (entity != null) {
try (InputStream stream = entity.getContent()) {
StringBuilder textBuilder = new StringBuilder();
try (Reader reader = new BufferedReader(new InputStreamReader
(stream, Charset.forName(StandardCharsets.UTF_8.name())))) {
int c = 0;
while ((c = reader.read()) != -1) {
textBuilder.append((char) c);
System.out.println(textBuilder);
System.out.println("\n" + response.getStatusLine().getStatusCode());
response.close();
} catch (UnsupportedEncodingException e) {
e.printStackTrace();
} catch (ClientProtocolException e) {
} catch (IOException e) {
} catch (AuthenticationException e) {
// TODO Auto-generated catch block
Tell me, please, what am I doing wrong?
Thank you in advance!
Best Regards!
ok thank you for this light.
Can you try that please (working fine for me). Just replace the user-agent and the PDMLinkProduct oid with your one. You will then see what is going wrong with your code :
private void sendPost() throws Exception {
String url = "http://pdm10.de/Windchill/servlet/odata/ProdMgmt/Parts";
HttpClient client = HttpClientBuilder.create().build();
HttpPost post = new HttpPost(url);
// add header
post.setHeader("User-Agent", USER_AGENT);
BASE64Encoder enc = new sun.misc.BASE64Encoder();
String username="wcadmin";
String password="ts";
String userpassword = username + ":" + password;
String encodedAuthorization = enc.encode( userpassword.getBytes() );
JSONObject json = new JSONObject();
json.put("Name", "TestWTPartFromOdata");
json.put("PhantomManufacturingPart" , false);
//"GatheringPart": false,
json.put("GatheringPart", false);
HashMap<String, String> am_map = new HashMap<String, String>();
am_map.put("Value", "separable");
am_map.put("Display", "Separable" );
json.put("AssemblyMode", am_map);
HashMap<String, String> df_map = new HashMap<String, String>();
df_map.put("Value", "ea");
df_map.put("Display", "Each" );
json.put("DefaultUnit", df_map);
HashMap<String, String> dtc_map = new HashMap<String, String>();
dtc_map.put("Value", "0");
dtc_map.put("Display", "Untraced" );
json.put("DefaultTraceCode", dtc_map);
HashMap<String, String> src_map = new HashMap<String, String>();
src_map.put("Value", "make");
src_map.put("Display", "Make" );
json.put("Source", src_map);
HashMap<String, String> cfm_map = new HashMap<String, String>();
cfm_map.put("Value", "standard");
cfm_map.put("Display", "Standard" );
json.put("ConfigurableModule", cfm_map);
json.put("EndItem" , false);
json.put("Context@odata.bind", "Containers('OR:wt.pdmlink.PDMLinkProduct:64091')");
StringEntity params = new StringEntity(json.toString());
"Name": "Part_P036",
"AssemblyMode": {
"Value": "separable",
"Display": "Separable"
"EndItem" : false,
"DefaultUnit": {
"Value": "ea",
"Display": "Each"
"DefaultTraceCode": {
"Value": "0",
"Display": "Untraced"
"Source": {
"Value": "make",
"Display": "Make"
"ConfigurableModule": {
"Value" : "standard",
"Display" : "Standard"
"PhantomManufacturingPart": false,
"Context@odata.bind": "Containers('OR:wt.pdmlink.PDMLinkProduct:64091')"
post.addHeader( "Authorization", "Basic "+ encodedAuthorization);
//post.addHeader("Accept", "application/json");
post.addHeader("Content-Type", "application/json");
post.addHeader("Accept","application/json");
post.addHeader("CSRF_NONCE","ypTCuzcDl4rmuSC3jMyM71JH+8+sgGbbnN6j1lJp29rV90TG/ces9FtN38Kc4FTZiPr08k5g2rfciBWO+qT1ig43pbvSjhr5ruy41FV2/9uUzRTvha2t/XhVouSRhB0=");
post.setEntity(params);
HttpResponse response = client.execute(post);
System.out.println("\nSending 'POST' request to URL : " + url);
System.out.println("Post parameters : " + post.getEntity());
System.out.println("Response Code : " + response.getStatusLine().getStatusCode());
BufferedReader rd = new BufferedReader( new InputStreamReader(response.getEntity().getContent()));
StringBuffer result = new StringBuffer();
String line = "";
while ((line = rd.readLine()) != null) {
result.append(line);
System.out.println(result.toString());
Hicham
Hi
The CSRF-NONCE is provided by the REST API end point :
https://<Windchill server>/Windchill/servlet/odata/PTC/GetCSRFToken()
I'm not sure that the "MY-TOKEN" string had been provided by this end point 🙂
Hicham
Thanks for the answer!
Yes, I copied my real token there, but I just decided to replace it so. 😅
I apologize for being misleading.
Here is the real tokens format that I am adding:
F4a464/MVN5bbrRdYtbXq+TnODYTPq9qbbHS2OOWM+xlT80oT7XgpumOIboWGtAvILbsnp18ZOHnR3FiI7CBxZn0dOZuDo3fIMTRne2lBpIJIt8qe6/ptv+fIREML4k=
// add header
"AssemblyMode": {
"EndItem" : false,
"DefaultUnit": {
"Value": "ea",
"Display": "Each"
"Value": "0",
"Source": {
"Value": "make",
"Display": "Make"
String line = "";
Hicham
I redid the code a bit.
Here's what happened:
private static void sendPost() throws Exception {
String url = "http://server/Windchill/servlet/odata/ProdMgmt/Parts";
// add header
String password="wc";
String encodedAuthorization = new String(Base64.getEncoder().encode(userpassword.getBytes()));
json.put("DefaultUnit", "kg");
json.put("DefaultTraceCode", "0");
json.put("Source", "make");
post.addHeader( "Authorization", "Basic " + encodedAuthorization);
post.addHeader("CSRF_NONCE","F4a464/MVN5bbrRdYtbXq+TnODYTPq9qbbHS2OOWM+xlT80oT7XgpumOIboWGtAvILbsnp18ZOHnR3FiI7CBxZn0dOZuDo3fIMTRne2lBpIJIt8qe6/ptv+fIREML4k=");
String line = "";
Here are the errors I get:
1)
Post parameters : [Content-Type: text/plain; charset=ISO-8859-1,Content-Length: 290,Chunked: false]
Response Code : 400
{"error":{"code":null,"message":"Context is not valid."}}
2)
Post parameters : [Content-Type: text/plain; charset=ISO-8859-1,Content-Length: 291,Chunked: false]
Response Code : 403
{"error":{"code":null,"message":"Windchill type is not instantiable"}}
I understand the problems in this line:
json.put("Context@odata.bind", "Containers('OR:wt.doc.WTDocument:1131319')");
but I don’t quite know what to indicate here 😞
HI
When you set a document instead of a container OID as paramter for Context@odata.bind, i guess that you need some more knowledge about Windchill architecture and context/container url.
Please check these two articles to understand Windchill architecture, and how to read a container oid :
https://www.ptc.com/en/support/article/CS212423 for windchill Architecture
and
https://www.ptc.com/en/support/article/CS233649 for container OID
hicham
Thanks for the info!
I just tried all the options, but my understanding was not enough.
Now I switched to the product, as mentioned in one of the articles, and copied the following OID:
OR:wt.pdmlink.PDMLinkProduct:112148
but it still does not work and produces the same error:
Response Code : 400
{"error":{"code":"INVALID_NONCE","message":"A potential security problem was detected. Refresh the page and try again. If the problem persists, contact your administrator."}}
I looked at the documentation, here is what this code means:
I also tried to run this code on the server, the following error appeared:
Response Code : 403
Here is what the documentation says about this:
But I used the admin user.
Help me please.
I found a mistakes.
Type must be Instantiable.
Here's how to do it:
Just as I understand it, the generated token can only be used by the user who received it.
Hicham,
Thank you very much for your help!
