Hello ,
I need to install Windchill-Workgroup-Managers and silent mode , I've tried everything but it doesn't go , someone did this could help me I already put in the script /S, /quiet, /silent, /qn and without success
@echo off
setlocal
rem Path to the .exe files
set “installers=D:\Windchill-Workgroup-Managers”
rem Install the first program
echo Installing Program1...
“%installers%\setup.exe” /silent /D=\C:\Program Files
echo Program1 installed successfully!
rem Add more programs as needed
echo Installation complete.
pause
Have you read this article yet?
Steps to perform Silent Installation of Windchill Workgroup Manager
Yes, but it's giving me an error, I've tried installing it with the local administrator user of the machine, but it's still giving me an error. I need to put it on several machines.
My help desk colleagues, who also prepare PCs for users, use a centralized system for installing new or upgrade packages.
For those from PTC (CreoView, Creo Platform Services or Windchill Desktop Integration) they use a command like the one below.
setup.msi /qn /norestart
My guess is that your problem could stem from rights, but you only wrote that it doesn't work with the error message in Portuguese so it becomes difficult to go into more detail.
I need a simple installation, even if I have to enter the local administrator's username and password
A thousand apologies follows in English
The folder already exists: C:\PTC\WWGM
The folder already exists: C:\PTC\WWGM\WFS
Folder already exists: C:\PTC\WWGM\WS
EXIT: the specified value has been saved.
Environment variable PTC_WFS_ROOT set to the value C:\PTC\WWGM\WFS
Environment variable PTC_WLD_ROOT set to the value C:\PTC\WWGM\WS
Place the folder on the Desktop and run again
Press any key to continue. . .
Do you know how I can open a ticket with PTC to check this? I can't find a product to open a more targeted ticket
I think you can use this selection or the one below.
Thank you very much
This morning I came across this article, which has just been edited.
https://www.ptc.com/en/support/article/CS406682
I don't know if it has to do with your problem, or you opened this call, but since it's very similar to the problem you reported, I'm putting it in this discussion.
