We are working on a task where it should have an input attribute with a suggestion box on a workflow task item.
I have created the data utility for the suggestion box. I need clue how to map it with my workflow variable(it is not straight forward as i do for type and attribute)
Kindly guide me
We accomplished this with a custom JSP template for the workflow task page. In this example, I was using a drop down for a WTUser that I wanted a custom limit on what users were selectable. Variable was called "EC_Creator".
<jca:describePropertyPanel var="ecCreatorPanelDescriptor" >
<jca:describeProperty id="EC_Creator" dataUtilityId="goodrichPrincipalSelector" />
</jca:describePropertyPanel>
You are able to add in the call out for the ID of the data utility.
<tr>
<td align="right" valign="top" nowrap><FONT class=tabledatafont>
<tags:taskPanelLabel propertyModel="${ecCreatorPropertyModel}" attrs="EC_Creator"/>
</td>
</tr>
Then later on in the template, you can call out its rendering.
Hello @SK_12337814
Here is an example how to use dropdown list in the workflow task input.
CS36017 - How to create a drop down list in a workflow instance task detail page of Windchill
Unfortunately, when I tried this example, I realized that the standard DataUtility is not supported in the task input page.
PS> you can study what following DU does and get idea how to implement own one.
com.ptc.windchill.enterprise.workitem.dataUtilities.CustomVariablesDataUtility
mentioned DU is used to display Variables from workflow on the Task page.
PetrH
<tr>
</td>
</tr>
thanks
buit should i use custom task form template here?
and how to likn with my workflow variable>?
This section of the documentation show how:
Yes, I used a custom JSP task page. when you describe the workflow variable, you can add a data utility ID. you must have this data utility registered in the site.xconf and class created.
Hi @SK_12337814,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
