8-Gravel
December 17, 2024
Add data utility to workflow variable
  • December 17, 2024
  • 2 replies
  • 1161 views
We are working on a task where it should have an input attribute with a suggestion box on a workflow task item.
I have created the data utility for the suggestion box. I need clue how to map it with my workflow variable(it is not straight forward as i do for type and attribute)
Kindly guide me
Best answer by avillanueva
We accomplished this with a custom JSP template for the workflow task page. In this example, I was using a drop down for a WTUser that I wanted a custom limit on what users were selectable. Variable was called "EC_Creator".
<jca:describePropertyPanel var="ecCreatorPanelDescriptor" >
 <jca:describeProperty id="EC_Creator" dataUtilityId="goodrichPrincipalSelector" />
</jca:describePropertyPanel>
You are able to add in the call out for the ID of the data utility.
<tr>
 <td align="right" valign="top" nowrap><FONT class=tabledatafont>
 <tags:taskPanelLabel propertyModel="${ecCreatorPropertyModel}" attrs="EC_Creator"/>
 </td>
 </tr>
Then later on in the template, you can call out its rendering.
HelesicPetr
Hello @SK_12337814
Here is an example how to use dropdown list in the workflow task input.
CS36017 - How to create a drop down list in a workflow instance task detail page of Windchill
Unfortunately, when I tried this example, I realized that the standard DataUtility is not supported in the task input page.
PS> you can study what following DU does and get idea how to implement own one.
com.ptc.windchill.enterprise.workitem.dataUtilities.CustomVariablesDataUtility
mentioned DU is used to display Variables from workflow on the Task page.
PetrH
avillanueva
23-Emerald I
23-Emerald I
December 17, 2024
<tr>
 </td>
 </tr>
8-Gravel
December 20, 2024
thanks
buit should i use custom task form template here?
and how to likn with my workflow variable>?
avillanueva
23-Emerald I
23-Emerald I
December 20, 2024
This section of the documentation show how:
https://support.ptc.com/help/wnc/r12.0.2.0/en/index.html#page/Windchill_Help_Center%2FWCCG_BusLogicCust_WorkflowAdmin_CustWorkflowTaskPages_Rendering.html%23
Yes, I used a custom JSP task page. when you describe the workflow variable, you can add a data utility ID. you must have this data utility registered in the site.xconf and class created.
