Does anyone know where I have to go to add a column to the list of available columns when customizing a My Tasks table view? I was able to add the column on our Change Notices page (browse>changes>change notices). I just need to display on people's home page. Currently it's not listed in the available columns to add.
Thanks in advance,
Greg
From our consultants:
1. Edit AvailableAttributes.xml Windchill\codebase\com\ptc\core\htmlcomp\createtableview\AvailableAttributes.xml and add following lines under WorkItem (Add highlighted lines)
<Class name="wt.workflow.work.WorkItem">
<Include name="wt.fc.Persistable"/>
<Include name="wt.ownership.Ownable"/>
<Attribute id="completedBy"/>
<Attribute id="name"/>
<Attribute id="reassigned" type="boolean"/>
<Attribute id="required" type="boolean"/>
<Attribute id="role" type="list" enumClass="wt.project.Role"/>
<Attribute id="workItemStatus" schemaId="status" type="list" enumClass="wt.workflow.work.WfAssignmentState"/>
<Attribute id="containerName"/>
<Attribute id="workitem_pbolink"/> <Attribute id="SaledOrderDescriptionWorkItem">
<Label resource="ext.mb.MBResource" key="SALES_ORDER_DESCRIPTION_LABEL"/>
</Attribute>
<Attribute id="SalesOrderNumberWorkItem">
<Label resource="ext.mb.MBResource" key="SALES_ORDER_NUMBER_LABEL"/>
</Attribute>
</Class>
2. Edit the Windchill\codebase\com\ptc\windchill\enterprise\enterpriseui.dataUtilities.properties.xconf and add the following lines under the <Service name="com.ptc.core.components.descriptor.DataUtility"> tag:
<Option serviceClass="ext.mb.CustomChangeNoticeAttributeDataUtility"
requestor="java.lang.Object"
selector="SaledOrderDescriptionWorkItem"
cardinality="singleton"/>
selector="SalesOrderNumberWorkItem"
3. Run "xconfmanager -p" to propagate the changes.
4. Place the DataUtility files under Windchill/src/ext/mb folder (create folders if necessary)
5. Execute the below command to compile the classes:
tools class -Dclass.includes=ext\mb\**
6. Restart the server and add the column to the view.
Works Great!!
Right next to "My Task" is a drop down, you can select "customize" and create your own view with any columns you want.
James,
I am asking how to add a column to the available columns list....
Sorry I misunderstood. Too bad, here I was thinking I may have actually solved someones windchill problem. I don't have an answer for that problem.
Create an alias/calculated attribute on "Work Item" type from type and atribute manager. Then you can see the attribute added under "Available columns" list which can be selected.
Just carefully tried this - cannot see my new test column. A few screen captures would really help. What info can you include in such an attribute for a work item (task).
thank you
The images are from Windchill 10.2 intance.
Created an alias attribute 'CNNumber' on Work Item type
Ashwini,
I am struggling with the mapping field...this attribute is something we created (we have customized CR and CN forms). Do you know were I would look for the mapping info?
You can refer the below link for mapping information
http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=TypeMgrAttrAliasMap&action=show
In my case the mapping entry is 'primaryBusinessObject^wt.change2.WTChangeOrder2~number'
Images very helpful. What is the exact text in the "mapping" field please?
Mike,
He has it listed above...primaryBusinessObject.....
My case is a little different as I want to display a column that is custom. I was told by my consultants that what PTC is devised is overly complicated and not necessary. I am getting step by step instructions for what we will be doing. I'll post them once I receive.
Ashwini,
How would the mapping change if I wanted to display a simple text attribute from the primary business object? Having troubles finding what to enter in the mapping line.
Greg
I also logged a case with PTC, here is the TSE's response:
I have been assigned to look into this issue. After doing further investigation, I have found below steps to add column to users Home -> Tasks table.
o Override/extend the corresponding builder to override the getSpecialTableColumnsAttrDefinition method to add the required column.
o Create a new DataUtility to fetch the column values
Greg,
As long as you are using 10.1 M040 or higher the methodology that Ashwini provided above is the path you should be using. Whether the custom attributes are modeled or typed it will work.
I guess I should have specified, we are using 10.0 M040
Jeffrey,
I have highlighted in the image which says mapping can be done only for modeled attributes. Please find it in the link http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=TypeMgrAttrAliasMap&action=show
Please let me know if i am wrong.
</Attribute>
</Attribute>
</Class>
Works Great!!
Hi Greg,
Would you mind sharing your Data Utility file? I am new to windchill and learnng customization.
Tem
Hello, GregOlson, please specify the 4 point where the Data Utility files are located
