Attempt to check in files fails, get message: A persistence error occurred. System message follows:
gchapman
One of the engineers here is attempting to check in models - check in fails and he gets the following message:
He is unable to find the system message to give a clue as to the failure... any thoughts?
10 REPLIES 10
Are the other users able to check in files? This sounds like a database issue. Do you see something in the method server logs? Error looks similar to a bug 10.2 M030 with delete workspace
I did find the persistence error occurred line
Looks like index is corrupted. After your DB backup try the below
SELECT
OBJECT_NAME,
OBJECT_TYPE
FROM ALL_OBJECTS
WHERE OBJECT_ID = 30101;
If is an index, try rebuilding it
ALTER "INDEX_NAME" INDEX REBUILD ONLINE;
Thank you
Binesh Kumar
Gordon,
Was the issue resolved after rebuilding the corrupted index?
Let us know if you're still seeing the issue with check-ins.
Hello Binesh
Even i am geetting the same erro , while deleting the Family table Instance in Windchill 11.0 m010
Hello Binesh,
Even i have been  facing the same error while trying to delete the latest itteration from the PDM.(Windchill 11.0)
I am having a very similar problem. I have 3 items in my work space, that are not check out, have + sign next to them indicating that they have been modified and updated. I can not check them out nor can I delete them without getting "A persistence error occurred. System message follows:"
Most of what I read above is over my head.
Pieface
6-Contributor
(To:gchapman)
The last time I received this error I had to check out the WTP's in the same Workspace and check the asm in.  The WTP's got checked in at the same time.
Dear gchapman,
Did u resolve this issue?
I'm facing same error while trying to check out the files.
Can you please help out with the solution.
Thanks in advance.
Sumanth
canderson
6-Contributor
(To:gchapman)
Had this issue today.  Same as all no real information as to the cause of the error.  Was checking out a EPMdocument along with 24 WTparts that were associated.  The workaround was to add the objects to a workspace.  Then I checked out only the EPMdocument.  Then I checked out all of the WTparts except the two that was causing the issue.  Then I checked out the last 2 WTparts with no error.
