I want to shrink the size (rows) or remove the column containing the comments for affected objects. It looks like each object in the affected objects table takes up 3-4 rows. We currnetly only add comments to the resulting object table. What file should I look to modify?
Hi Greag,
Go to pick a view --> Customize
from the next window click on edit view .
Afterr that go to set column display and from there you can select what column you want to dispaly at the table.
Kaushik
Hi Greag,
Kaushik
Thanks for the info. For some reason on my system I could not exclude comments by modifying views. I had to deselect it by hovering over the right side of a column, clicking the down arrow that appeared, selecting column, and then I could deselect comments. I wish the column down arrows would stay shown all the time...out of sight out of mind.
Greg
Hi Greg,
You can deselect it but I guess next time when will you again create the change task the comment will come again so every time you have to Deselect whenever you will create a new task.
That change is not permanent.
Kaushik
Once again our system must be different than yours, our changes will stay until browser cache is cleared.
