Hello, please tell me how to use Query Builder to get a report that will display the contents of the "Process Status" table from the "Promotion Request"?
I want to output all the queries for a certain period, but I failed in solving the issue.
I have a report that returns information close to what you're looking for. Try joining these:
Context is optional, if you don't need it for your reporting, you can leave it out. (I like having that info).
WF Voting Event Audit contains the user's vote and user comment. It is only filled in if the task is completed. If you want to have this info, but also want to return open tasks that aren't completed yet, you'll need to use the "Outer Join Against " option on the join, set to WF Voting Event Audit.
WF Assigned Activity is where you can get Task actual start and actual finish
Workflow Process is where you can get info on the overall process, like start time and finish time as not all tasks may be assigned when the workflow is initiated.
Below a list taken from PTC TS article about query builder report for Promotion e Workflow.
A more comprehensive list in this document
Take a look also to this article
| How to generate a report with events from workflow tasks |
| https://www.ptc.com/en/support/article/CS32218 |
| How to retrieve records for delegation/reassignment |
| https://www.ptc.com/it/support/article/CS39534 |
| Report listing all open Work Items assigned to a user within a specific context |
| https://www.ptc.com/en/support/article/CS42158 |
| How to add Promoted By and Promoted On in advanced search criteria |
| https://www.ptc.com/it/support/article/CS55947 |
| Report to fetch Promotion Request records |
| https://www.ptc.com/en/support/article/CS112325 |
| How to generate report to display "Promoted on" attribute from the Maturity History table of an object |
| https://www.ptc.com/en/support/article/CS115668 |
| How to get Primary Business Object name from WfVotingEventAudit table using Report Manager |
| https://www.ptc.com/en/support/article/CS130932 |
| Report to fetch completed task with approvers |
| https://www.ptc.com/en/support/article/CS137008 |
| How to generate a report that will show the documents, their Promotion requests and the name of the context |
| https://www.ptc.com/it/support/article/CS141905 |
| Windchill Data Model for Workflow related objects |
| https://www.ptc.com/en/support/article/CS153902 |
| Report to fetch reassign information of a promotion request |
| https://www.ptc.com/en/support/article/CS162802 |
| Query all workflows to determine for class/method used in them |
| https://www.ptc.com/it/support/article/CS168660 |
| Report to list workflow tasks assigned to disconnected users |
| https://www.ptc.com/it/support/article/CS178728 |
| How to generate QML report for the Tasks past deadline |
| https://www.ptc.com/en/support/article/CS180709 |
| Report returning runtime routing list for Setup Participants from a workflow |
| https://www.ptc.com/it/support/article/CS210243 |
| In which database tables are stored the workflow execution objects? |
| https://www.ptc.com/it/support/article/CS214035 |
| Report to find out values of Promotion Preferences |
| https://www.ptc.com/it/support/article/CS215586 |
| Report to fetch the Open Task assigned to User in a Product |
| https://www.ptc.com/it/support/article/CS246581 |
| How to link SignatureLink and Workflow Process table and fetch data from them |
| https://www.ptc.com/it/support/article/CS258046 |
| Report to get the Actual Start and Actual Finish of Assigned and Completed Workflows |
| https://www.ptc.com/it/support/article/CS284873 |
| Is it possible to display in Query builder (tasks from the WFBlock) and (tasks from the WF) |
| https://www.ptc.com/en/support/article/CS306945 |
| How to query or get report for activities that are of type "Set Up Participants" |
| https://www.ptc.com/en/support/article/CS310537 |
| How to display all open tasks for all users on my homepage |
| https://www.ptc.com/en/support/article/CS321622 |
| Report to list processes which may have tasks existing under them but are not open |
| https://www.ptc.com/en/support/article/CS341897 |
| How to get an assigne name (in a role) from a workflow (Community) |
| https://community.ptc.com/t5/Windchill/In-the-query-builder-report-how-to-get-an-assigne-name-in-a-role/m-p/263254 |
| How to generate a report of all completed Promotion Requests? |
| https://community.ptc.com/t5/forums/replypage/board-id/Windchill/message-id/63198 |
| Query Builder Lifecycle History Example |
| https://community.ptc.com/t5/Windchill/Query-Builder-Lifecycle-History-Example/td-p/444736 |
| Report on Workflow Processes |
| https://community.ptc.com/t5/Windchill/WindChill-Reports-Query-Builder-Locating-Fields/m-p/737015#M64301 |
| Report showing date of last promotion |
| https://community.ptc.com/t5/Windchill/Report-showing-date-of-last-promotion/td-p/223769 |
thank you for the links, I've seen your message before.
https://community.ptc.com/t5/Windchill/Query-to-get-history-of-Change-Notice-like-Created-by-Number/td-p/185313
But not one solution did not give the desired result
Most of the support articles were written in response to a user request (some I did myself).
If you have active maintenance support, you could open a call and ask if they can give you a suggestion from which to build your report.
That way, if there is a positive response, I could add this to my list as well.
There isn't a "Process Status" table on Promotion Request - likely you are interested in something similar.
Regardless, I can help if you are more specific. Maybe screen capture from a Prom Req what you'd like to see in a report.
thank you very much for your answer. You helped me, this is what I need.
Please tell me how I can add a list of options to choose from for the Context?
Glad I could help!
I think the query reports will only give you a drop down list if the parameter is constrained by an enumerated list. I'm not really sure how to get a drop down list otherwise.
thank you! very helpful.
