From Search-Objects webject im getting the parts details, and Context-Name Webject is the custom webject which we have created. Using Return-Group webject im combining both webject data. But the data is not combining. The custom data is showing for only the last object.
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Search-Objects" type="OBJ">
<ie:param name="INSTANCE" data="$(@FORM[]supporting-adapter[*])" delim="!" valueSeparator="!" default="<%=com.infoengine.au.NamingService.getVMName()%>"/>
<ie:param name="TYPE" data="wt.part.WTPart"/>
<ie:param name="attribute" data="obid,number,name,version,lifeCycleState,containerReference" delim=","/>
<ie:param name="GROUP_OUT" data="objectSearched"/>
</ie:webject>
<ie:forEach groupIn="objectSearched" groupOut="Obj">
<ie:webject name="Context-Name" type="EXT" use="ext.customWebject.ExampleCustomWebject">
<ie:param name="COLUMN" data="obid"/>
<ie:param name="GROUP_IN" data="Obj"/>
<ie:param name="GROUP_OUT" data="ActualResult"/>
</ie:webject>
</ie:forEach>
<ie:webject name="Return-Groups" type="GRP">
<ie:param name="GROUP_IN" data="objectSearched"/>
<ie:param name="GROUP_IN" data="ActualResult"/>
</ie:webject>
