Moving Windchill 11.1 DB to another SQL Server instance
I am using Windchill Aerospace & Defense Release 11.1 and Datecode with CPS F000
I moved the Windchill Database to a new SQL Server instance and services are not starting and the application is down
Windchill Risk and Reliability Long Running Task Service 11.1 - Service not starting
Windchill Risk and Reliability Object Broker Service 11.1 - Service not starting
Could not connect to
net.tcp://************:12202/Relex.BusinessObjects.IService.
The connection attempt lasted for a time span of
00:00:02.0625271. TCP error code 10061: No connection could
be made because the target machine actively refused it
*.*.*.*:12202.
Here are the errors that I faced
in Event Viewer under "Windows Logs > Application":
Service cannot be started. System.Data.SqlClient.SqlException (0x80131904): Invalid object name 'FileInfo'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Bool...
