I am trying To Delete Custom Table view which is created as System Table view and hence no option available for delete from UI and as i want to do it using loadfromfile Utility any one have come across this..
Hi @MB_10034486
If you log in as an administrator why do you not use the delete button from the table menu?
What error do you see if you use it?
I guess that you use a load from file functionality without specify a user so you can not delete it. as a system
This is a consequence of your action.
So the resolution is: delete it from a database or change the owner in the database. There is no UI operation that can help.
I have one advice. If you use load from file and you do not know all consequences really use a backup on your developer(test) system before you do it in a production. . You can revert the backup when ever you need.
PetrH
Hello Custom tables are created by users , can elaborate on "Custom Table view which is created as System"
Hello @Fadel i have created Customized Table View for Structure tab but that view is saved with "System" as creator and its does not have option to delete in UI and so i am sharing below image for reference so my query is if its possible to delete a table view which has Creator as "System" from LoadFromfile utility :
can you import , run and share result of attached report when running mention the tableview name :
Hello @MB_10034486,
It looks like you have a response from a PTC expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi @MB_10034486
PetrH
