Getting error while checking out a component from windchill to do some modifications.
ERROR MESSAGE: "Operation failed because the user did not have the necessary permission on the following objects to perform the operation".
Help me with the solution.
To close this community thread on permission errors when checking out a component
Summary and list of references:
Hello Ankit
Please check your rights for the product to which component belongs to, if you have only Member access you cant check out , Also check the state of that component ,if it is in released state you cant not checkout , it depends on how the configuration is made in Windchill in your company
Getting same error/message even if user has "Full Control" of the object.
Even if the user has Full Control, the file location may prevent the checkout.
Post an image of the Information page for the object.
