New Windchill Administrator here...
A colleague of mine created several Products but I can't tell what context they were created in. Are they at the site level or in a particular organization. I thought clicking on the info button might show it but no luck.
Is there any visual representation of the relationships between contexts that I can use? Like this one that is on the Learning Connector?
Rosemary,
All products are going to belong to an organization. By default Organization info is hidden in the UI. You can expose it by setting the following preference in Site > Utilities > Preference Management:
Display > Expose Organization = Yes
If that is set then you will see the organization info displayed in the Product Details
Rosemary,
Thank you! I've been a Creo user for the last 16 years so getting used to the Windchill UI is quite a shift!
