Version: Windchill 12.1
Use Case: I need to create structures for a part file where it hold the BOQ .Does windchill rest api provide support creating BOQ and How?
Description:
Hi @SS_10923513
Try to search the WRS documentation.- https://yourwch.com/Windchill/netmarkets/html/wrs/doc.html
PTC.ProdMgmt
[ Base URL: wch:443/Windchill/servlet/odata/v5/ProdMgmt ]
The Usage link is a link between parent and child part.
PetrH
Could the following article help? Article - "How to get entire BOM Structure for a given Part/Assembly along with Alternates and Substitutes for components in the structure in Windchill Rest Services": https://www.ptc.com/en/support/article/CS350014
Can you provide more detail in this?
This article helps me in getting the structure created ,can you help me with creating those BOM structure using rest api
Hi @SS_10923513
PTC.ProdMgmt
PetrH
Hello @SS_10923513,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution. If you found a solution yourselves, please document it in your topic and mark it as accepted solution.
Community Moderation Team.
