How to get list of Released objects(documents) in mail notification in promotion approval request?
maheshkumar
2-Explorer
Hi Gurus,
I have one customer requirement that, After approving the list of promotion objects, those object names, numbers and version should be included in a mail notification.
Kindly suggest if there is any work arounnd/customization code available for the same.
Mahesh Kumar G
11 REPLIES 11
Declare a string workflow variable. Use the below API to get Promotion Targets. Cast the query result to respective object types, get the name and number, store it in the variable - may be append a new line after each entry. Use the variable in activity and emails
QueryResult qLatest = wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
Thank you
Binesh Kumar
Medtronic - MITG
Hi Binesh,
Thanks for your reply, As i m beginner to customization, Could you please a sample code for The same. I am not sure how to Cast query results to Respective Documents.
Mahesh
Mahesh: You can do something like the following starting with Binesh's line to get the promotion request targets
while (qLatest.hasMoreElements()) {
     Object obj = qLatest.nextElement();
     String name;
     String number;
     if(obj instanceof EPMDocument) {
          EPMDocument epmDoc = (EPMDocument)obj;
          number = epmDoc.getNumber();
          name = epmDoc.getName();
     else if(obj instanceof WTPart) {
          WTPart wtPart = (WTPart)obj;
          number = wtPart.getNumber();
          name = wtPart.getName();
Randy
Sorry for delayed reply
Exactly, If you like to add a table for formatting.
public static String getPromotionMembers(wt.maturity.PromotionNotice pn) {
String tempStr = null;
try {
  @SuppressWarnings("deprecation")
  System.out.print("*************Found " + qLatest.size() + "  objects in this promotion");
  tempStr = "<table><thead><tr style=\"background-color:yellow; font-weight:bold;\"><td style=\"padding:5px; border:.5px solid black;\">Promoted Items</td><td style=\"padding:5px; border:1px solid black; text-align:center;\">Version</td></tr></thead>";
   Object obj = (Object) qLatest.nextElement();
   // System.out.print(obj.getClass());
   if (obj instanceof wt.epm.EPMDocument) {
    EPMDocument epmd = (EPMDocument) obj;
    tempStr = tempStr + "<tbody><tr><td style=\"padding:5px; border:1px solid black;\">";
    tempStr = tempStr + epmd.getCADName() + "</td>" + "<td style=\"padding:5px; border:1px solid black; text-align:center;\">" + epmd.getIterationDisplayIdentifier() + "</td></tr>";
   } else if (obj instanceof wt.part.WTPart) {
    wt.part.WTPart wtp = (wt.part.WTPart) obj;
    tempStr = tempStr + wtp.getNumber() + "</td>" + "<td style=\"padding:5px; border:1px solid black; text-align:center;\">" + wtp.getIterationDisplayIdentifier() + "</td></tr>";
   } else if (obj instanceof wt.doc.WTDocument) {
    wt.part.WTPart wtd = (wt.part.WTPart) obj;
    tempStr = tempStr + wtd.getNumber() + "</td>" + "<td style=\"padding:5px; border:1px solid black; text-align:center;\">" + wtd.getIterationDisplayIdentifier() + "</td></tr>";
  tempStr = tempStr + "</tbody></table>";
  System.out.println("************* Objects undergoing promotion are " + tempStr);
} catch (WTException e) {
  e.printStackTrace();
return tempStr;
Binesh Kumar
Medtronic - MITG
Hi Binesh & Randy Jones,
Thanks alot for your information.
I would use the same get back to you if any information is needed further.
Mahesh
Sure, forgot to mention. If you are using my code, in the activity add  {tempStr}. You can also place the compiled code somewhere in codebase and refer that within the workflow
Hi Binesh,
I have used in an Acitivity Start Transition area, while checking the Syntax following errors occurring,
Checking Syntax...
E:\ptc\Windchill\temp\WfExpression3717567.java:85: error: cannot find symbol
  symbol:   class QueryResult
E:\ptc\Windchill\temp\WfExpression3717567.java:85: error: variable qLatest is already defined in method executemethod_2(Object[])
  symbol:   variable pn
E:\ptc\Windchill\temp\WfExpression3717567.java:119: error: cannot find symbol
  symbol:   class EPMDocument
E:\ptc\Windchill\temp\WfExpression3717567.java:203: error: cannot find symbol
    } catch(WTException e) {
  symbol:   class WTException
Note: E:\ptc\Windchill\temp\WfExpression3717567.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
6 errors
Syntax check complete.
Thanks & Regards,
Mahesh Kumar G
Please use the below . In wf expressions you have to call the methods by its full package name.
  try {
                                                             wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
  wt.fc.QueryResult qLatest = wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
     wt.epm.EPMDocument epmd = (wt.epm.EPMDocument) obj;
     wt.doc.WTDocument wtd = (wt.doc.WTDocument) obj;
  } catch (wt.util.WTException e) {
Binesh Kumar
Medtronic - MITG
Hi Binesh,
Its working fine, Thank you , Thanks alot.
Mahesh
Hi Mahesh,
What steps did you take to make it work?
Wagner
Hi Binesh,
I couldn't get that result.
Wagner
