How to manage action menu on organization based
maakbulut
Version: Windchill 13.0
Use Case: I need to change the shortcut buttons in the folders based on organization. How can I manage the FolderManagement-actionModels.xml file based on organizations?
Description:
I have two organizations and I need to manage the folder shortcut buttons in each organization separately. When I modify the FolderManagement-actionModels.xml file it reflect all organizations. How can I separate the xml file organization based?
6 REPLIES 6
I am pretty sure what you are asking for is not possible. If you are managing multiple orgs in same instance of Windchill, there are somethings they need to agree upon. If they cannot agree, you might have to split into two separate Windchill instances.
RandyJones
20-Turquoise
(To:maakbulut)
It might be possible to use a custom filter. I have one that hides if the invoked from container is a Project.:
https://community.ptc.com/t5/Windchill-Customization/Hide-Remove-customized-action-from-Project-Link-for-WTPart/m-p/927927#M98%3Fsource=search
WTContainerRef cr = criteria.getInvokedFromContainer();
// add in the getOrganizationName() method to get the org name
// and filter base on that
String orgName = cr.getReferencedContainer().getOrganizationName();
if (orgName.equals("Org1")) {
	status = UIValidationStatus.HIDDEN;
} else {
	status = UIValidationStatus.ENABLED;
I was not thinking of extensive customization but a filter could be an easy solution since you can apply it to any action you wanted and its is configured in the xml files that @maakbulut was asking about. They would have to trace out all actions that they wanted to hide and apply that filter to all definitions.
HelesicPetr
(To:avillanueva)
Hi all.
My question is if you need to just play with the ribbon menu where the actions are as shortcuts or you really need to hide the action from the menu at all.
If you want to just show shortcut actions in the ribbon menu based on organization, it is not possible based on organization.
If you really need to hide the action from the action menu then an own custom filter is the solution.
PetrH
Maybe another option is to use Standard Profiles at the organization level?
I'm not clear if you are trying to hide a PTC action or adding your own.  If adding your own, this help center page shows you how to add your actions to the Standard Profile options.
https://support.ptc.com/help/wnc/r12.0.2.0/en/index.html#page/Windchill_Help_Center/WCCG_UICust_GenericUICust_CustomizeRoleBasedUIFunctions.html
Step 8 at the end of this article shows an example of controlling custom GUI actions using Profiles.
https://www.ptc.com/en/support/article/CS211115
If these are PTC's default actions, then would some of these actions work in the standard profile? (see attached picture)  You can turn them on in one organization and off in the other.  Then assign users to the profiles according to organization.
Not sure if it is possible to automatically assign users to profiles.
Otherwise, @RandyJones's UI validator is probably the way to go because it isn't linked to the user's assigned profiles.
Hi @maakbulut,
Anurag
