Hi all,
By reading the WRS manual I can see that some tables can be expanded: CR's can be expanded to show AffectedObjects.
/Windchill/servlet/odata/v5/ChangeMgmt/ChangeRequests?$select=Description,AffectedSystem,LastModified,Name,Number&$filter=startswith(Name, 'Foo-')&$count=false&$expand=AffectedObjects
Also the manual shows these available to expand in a Parts query:
$expand=Uses/$ref
$expand=AlternatePart
$expand=Alternates($expand=AlternateFor
$expand=Alternates($expand=Alternate)
$expand=Alternates($expand=AlternatePart
$expand=SubstitutePart
$expand=PartDocAssociations($expand=RelatedCADDoc)
$expand=PartDocAssociations($expand=RelatedPart)
These are shown in example code. Are there other table relations that can be expanded? I was hoping to see RelevantRequestData as something which can be expanded.
Ok, yes, this is configurable, but what is the default?
And which server-side XML configures this?
thanks
Rick
Hi @rleir
Perhaps it's 'navigation criteria' that indicates what can be expanded, then it seems to depend somewhat on context.
For example, there is a 'resultingobjects' nav criteria, but we would not expect to expand change request to on it.
Hi all
Here is a server-side file (snippet below) which might be part of the answer:
Windchill_11/Windchill/codebase/rest/ptc/domain/ChangeMgmt/v5/entity/ChangeItems.json
This suggests that we can expand "organizationOwned", "VersionedChangeMgmt" and a few others.
Now my question is a bit clearer: "Where is the documentation for WRS saying what can be expanded in each domain"?
Rick
A snippet from the file:
"inherits":[
"name": "organizationOwned"
"name": "VersionedChangeMgmt"
"name": "LifecycleManagedChangeMgmt"
"name": "ProcessLinks"
"name": "ProcessObjects"
"name": "ReferenceLinks"
"name": "ReferenceObjects"
"name": "AffectsLinks"
"name": "AffectedObjects"
More on the above. My info is for ChangeRequest.
I am using https://domain/Windchill/netmarkets/html/wrs/doc.html -- In the right frame, GET /ChangeRequests
Clearly I need to learn more about this. I tried expanding these:
"name": "organizationOwned" -- no, cannot be expanded
"name": "VersionedChangeMgmt" -- no, cannot be expanded
"name": "LifecycleManagedChangeMgmt" -- no, cannot be expanded
"name": "ProcessLinks" -- nothing for us,
"name": "ProcessObjects" -- nothing for us
"name": "ReferenceLinks" -- links to a wt.change2.ChangeReferenceLink
"name": "ReferenceObjects" -- links to another ChangeRequest
"name": "AffectsLinks" -- links to wt.change2.RelevantRequestData2 which you will recognize when you have been using QueryBuilder
"name": "AffectedObjects" -- links to Documents
Hi @rleir
Hi Rhart
Good eye, the navigation criteria identifies things that can be expanded. I marked your reply as the solution, thanks! Though there seem to be some big gaps in the doco for the 'expand' feature.
In a Change Request, AffectsLinks links to a wt.change2.RelevantRequestData2 OID number. Compare this in QueryBuilder: you can link from a Change Request to a Changeable, typically a Document or Part. But with ODATA you just get a RelevantRequestData2 OID number. Can you use that and identify the Document via an ODATA query?
Sometimes in ODATA examples they show nested 'expand' clauses. I tried a few possibilities, such as $expand=AffectsLinks($expand=RelevantRequestData2). But no luck, you could be nearly correct but a single character error or wrong case can make the query fail with a useless message.
thanks
Rick
Another way to do this is view the $metadata for the endpoint and look at the available Navigation Properties.
E.g. /Windchill/servlet/odata/v8/ChangeMgmt/$metadata
<EntityType Name="ChangeRequest" BaseType="PTC.ChangeMgmt.GenericChangeRequest">
<Property Name="COMMERCIALLY_RESTRICTED" Type="Edm.String">
<Annotation Term="PTC.SecurityLabel"/>
</Property>
<Property Name="CabinetName" Type="Edm.String">
<Annotation Term="PTC.ReadOnly"/>
</Property>
<Property Name="ChangeAdminI" Type="Collection(PTC.ChangeMgmt.ChangeAdmin)"/>
<Property Name="Complexity" Type="PTC.EnumType"/>
<Property Name="EXPORT_CONTROLLED" Type="Edm.String">
</Property>
<Property Name="FolderLocation" Type="Edm.String">
</Property>
<Property Name="FolderName" Type="Edm.String">
</Property>
<Property Name="IPCopyrightStatement" Type="Edm.String"/>
<Property Name="IP_CONTROLLED" Type="Edm.String">
</Property>
<Property Name="MarshallProprietaryData" Type="Edm.Boolean"/>
<Property Name="NonRecurringCost" Type="Edm.String"/>
<Property Name="ObjectType" Type="Edm.String">
</Property>
<Property Name="ProposedSolution" Type="Edm.String"/>
<Property Name="ProposedSolutionSummary" Type="Edm.String"/>
<Property Name="RecurringCost" Type="Edm.String"/>
<Property Name="RequestPriority" Type="PTC.EnumType"/>
<Property Name="ReservedBy" Type="Edm.String">
</Property>
<Property Name="SECURITY_CAVEAT" Type="Edm.String">
</Property>
<Property Name="SECURITY_CLASSIFICATION" Type="Edm.String">
</Property>
<Property Name="TeamTemplateName" Type="Edm.String">
</Property>
<NavigationProperty Name="ChangeAdministratorI" Type="Collection(PTC.PrincipalMgmt.Principal)"/>
<NavigationProperty Name="CRAffectLinks" Type="Collection(PTC.ChangeMgmt.RelevantRequestDataLinkItem)" ContainsTarget="true"/>
<NavigationProperty Name="Context" Type="PTC.DataAdmin.Container" Nullable="false"/>
<NavigationProperty Name="Folder" Type="PTC.DataAdmin.Folder"/>
<NavigationProperty Name="Attachments" Type="Collection(PTC.ContentItem)" ContainsTarget="true"/>
<Annotation Term="Core.Description">
<String>ChangeRequest</String>
</Annotation>
<Annotation Term="PTC.Operations">
<String>READ,CREATE,UPDATE</String>
</Annotation>
