Is there a way to query the team members selected for a particular promotion request and then check to see if a minimum number of participants was selected for a particular role? We have a promotion request workflow where we have set the number of required participants equal to 2. If the user submitting the request forgets to select approvers or only selects one, then the process hangs. Any ideas?
Benjamin Wilcox – IntelliServ<sup>™</sup>
PPM & PDM Administrator
Randy,
Thanks for the prompt reply. I have tried that approach, but the syntax check fails, so I am guessing that the promotion request object workflow must require a different way to read the team members. Do you (or anyone else)know how to query the team/participants on a promotion request object?
I tried that in a conditional, but I get an invalid flag error when checking the syntax (see attached screenshot). I have gotten this to work in workflows that are not for promotion request objects, but I cannot get it to work in the workflow for a promotion request object.
I went ahead and tried it, even though I got the Invalid Flag error, and it seemed to work fine. I don't know why the syntax checker doesn't like it....
Thanks, Randy, for your help.
In Reply to Ben Wilcox:
