This is more of a post letting others know what I encountered today with my Chrome-Windchill connection, but if anyone knows what is going on that would be great to know. It seems that Chrome recently updated their browser, mine is showing 83.0.4103.97, and I am now having issues with it. I have cleared all the history out of Chrome and it still has the issue. The issue has been seen across multiple computers, is that during the creation of a CN, when you go in and edit the task during that creation a blank window pops up with the spinning circle of death. I am on Windchill 11.2.1.0. The only error that is in any of the logs is:
2020-06-05 07:51:47,667 ERROR [ajp-nio-127.0.0.1-8015-exec-1] com.ptc.windchill.enterprise.change2.tags.ChangePropagationTag <USERNAME> - action oid was null
I have opened a support call and am waiting to hear back from them.
I don't know if anyone else has seen this yet or not.
So Far - My Work-Around (Clearing Cache from within Chrome) has held fine. I am on my own laptop/I am administrator on the laptop without much IT Oversight. Connecting to Cloud Windchill Systems (AKA not on a company network)
I have been switching between Development, Test, QA and Production Servers.
Primarily Making Workflow Template Changes.
But Creating Change Notice/Change Activities as well.
Majority of Users are NOT reporting any issues and have continued to work. Creation IT can not roll back the Chrome Build. And they are suggesting Edge for this Users Affected. The Heavy users have not seen any issue yet.
But a Ticket with PTC has been opened so that PTC can give formal response.
Note: For the Thread: PTC Did create an Article to Track the Issue: CS326191
Sounds like you are lucky! I still have the problem even after:
not sure why it works for one but not the other. I guess the users it works for can be glad! 😀
The TSE handling my case pointed me to the article you referenced.
SPR 10134786 has been logged by R&D.
Could please somebody verify if they still can create a new subtype in the Type and Attribute Manager? E.g. create a subtype for a WTDocument. I have the same spinning circle.
I belief the Chrome problem has something to do with the lightbox.
Yes, I experienced this yesterday. Cannot create new Reusable Attribute in latest version of Google Chrome for Windows 10 on Windchill 11.1 M020 CPS11.
A brief update - the R&D team has been able to confirm it is an interaction between Light boxes and Chrome 83.0.4103.97. The team is trying to dig in more.
Testing with the latest Chrome branch (Chrome Canary 85) we have not seen these issues reproduced.
What is Light boxes?
I had the same question.
This is from Wikipedia:
Lightbox is a JavaScript library that displays images and videos by filling the screen, and dimming out the rest of the web page. [1] The original JavaScript library was written by Lokesh Dhakar. [2]
Here is a link to the Wiki page:
Hello Jeff,
I tried the dev version of chrome 85 and the latest build also has the issue.
I attached also video where the history had been cleaned.
Thanks. Will update after comparing this version with the build that R&D validated against.
Same issue here 😞 Using Windchill 11.0 M030 CPS 14 and Edge Chromium 83.0.478.50.
And also see the issue when using Chrome version 83.x.x.x
Funny thing is, we just moved all our users from Internet Explorer to Edge, as the performance is much better.
I really hope there will be a fix to this other than waiting for Windchill 12 or some unknown future Edge/Chrome version.
/Kim
We'll need you help in reproducing the issue because we're unable to. I'm looking for a volunteer to work with our R&D folks - may be a webex where we can both exchange what we observe and figure out how to reproduce it on a PTC system.
@DeviVijayakumar, I have C15432860 open. Feel free to reach out if you need me to reproduce the issue.
This isssue only persist on non SSL layer (HTTP) WIndchill URL.
With SSL Layer (HTTPS) WIndchill URL there is no problem occuring..
How do we switch to HTTPS?
Can you please explain to the community how is possible that PTC has decided not to fix in 11.1 while R&D cannot reproduce the issue???? Seems illogical to me.... If you cannot reproduced it, how can you make that decision?
See CS326191 or attached screenshot.
It doesn't say they won't fix 11.0 or 11.2 through.
R&D has been working on this with priority and has identified a potential fix now. The fix is currently being tested. After adequate verification, we'll look into back-porting to older supported releases based on technical and other considerations.
Chrome just rolled out a new version Monday June 15th 83.0.4103.106
It appears to work for me. It automatically updated to this version when I checked the version I was running.
I got this message when checking the version
After restarting Chrome it now says this.
I tested the new version.
For me, it worked only the first time (e.g. set state on resulting objects).
After that doesn't work anymore...
You right.
The next build behaves same way as the previous one in my case.
The first try to open the lightbox window worked, then it doesn't.
Same behavior if you clear the cahced files.
I tried the new version, customer tried new version of chrome with same issue.
Chrome version 83.0.4103.106
PetrH
Hello All,
An important note:
Chrome issue(Adding new attributes, global attributes, Set state in the CN DetailPage, Editing the ChangeTask in edit wizard of CN and there would be more places with the popup inside window.)
RK
OK then in my side Windchill 11.0 M030 CPS17 with both layer of SSL(http & https)
it is working in https and not http..
