Skip multiple revs in Revise?
pcnelson
Is there any way to jump ahead several Rev's in WC? For example, an object is at A and needs to be at F, can it be Rev's somehowin one action? Of does the user have to move it each rev: A,B,C,D,E,F,? There are multiple objects that are affected, otherwise they would just do it manually. Thanks!
pwilliams-3
(To:pcnelson)
You can configure a preference to allow the user to select the appropriate revision during the revise. No need to revise several times.
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CE5B9D.BB307030]
avillanueva
23-Emerald I
(To:pcnelson)
If it's a WTDoc or Part, there is a preference to allow Inserting revisions. Appears under File menu in Folders UI.
