I have created a custom Versioning Scheme which should work with State Change from Approved -> Released ( i.e A.1 (Approved) will change to 1.1 (Released) State change either manually or when triggered in custom Workflow)
Has anyone encountered such issues, as this custom versioning is working for Object Revise action but not for Set State action / in Workflow State Change
Your support is appreciated. Thank you.
Lifecycle Transition:
where highlighted series is my Custom versioning Series name
You can create a workflow to trigger when the object reaches the Released state. Put the necessary additional steps in that workflow. That way, whether the objects is promoted or you use a set state, the secondary workflow will be triggered and the same steps will be performed for either case.
Which software are you using?
Windchill 12.0
Hello @RB_10356553
The versioning schema is change only during Revise action.
Set state do not change it also Promotion do not change it.
You can set autorevision during Promotions request that the object is autorevised and then the versioning schema is changed.
PetrH
Thanks HelesicPetr.
Hi Helesic,
If we use Automatic Revision Mode it will automatically revised and version is changed. from inwork to released (SOP)
but in lifecycle we marked Revise for inwork(sop inwork), so at that time state is also changed to inwork (sop inwork) not to released
(SOP)
kindly share your idea.
Hi @Boopathy
This is a way how it works.
Auto Revision is activated in the target promotion state, and how the revision is set then the new revision is in the target revise state.
So if you need that the autorevision finish in the SOP state, then you need some midle state where the promotion promote the objects and autorevision is activated and the result new revision will finish in the SOP state.
PetrH
Hi Helesic,
if we add new middle state. then the new state will displayed in information page right ??
for example (SOP Release).
Yes.
If you need a argument that this is the easiest way how to achieve that final Released object will be with new revision label and it stays in the real released state and the most important point is that you can revise from released state to inwork.
I have experience where the autorevision was used from Released state to Released state. On the first view it worked, but change process needed Set State from Released state to in-work because you can define just one revise transition from one state. Thanks that I have always argument why to use the "midle" state for autorevision.
PS> with code customization you can achieve whatever you can imagine 😄 but it takes time
PetrH
Hi Helesic,
thanks for your quick assistance.
so we need to add new state and it'll display in information page.
this is what you are trying to say right. kindly confirm please.
Hi Helesic,
Thank you for taking the time to do this.
