Unfortunately, this is not clearly documented in the 10.0 Windchill Help Center. At 10.1, you will no longer see the information about this functionality if you select "Pro/INTRALINK" as the Solution on the Help Center configuration tab, and we'll ensure that the support information is also included in the text.
Jane
Jane Zupfer
VP, Windchill Publications
T 763.957.8299
E -
