X Bom Transforamtion
AP_10483126
If we have only the XBOM transformation and dont have the MPMLink installed will we get access to OOTB com.ptc.windchill.mpml.algorithm ?
8 REPLIES 8
Fadel
23-Emerald I
(To:AP_10483126)
  • MPMLink Module introduces algorithm com.ptc.windchill.mpml.algorithm.ViewToLifeCycleAlgorithm
  • The class is inside the MPM JAR , so mpmlink is needed
Fede
AP_10483126
(To:Fadel)
will this be available also with BOM transformations?
Fadel
23-Emerald I
(To:AP_10483126)
i don't really know what do you mean by BOM transformation , can you elaborate ?
Fede
AP_10483126
(To:Fadel)
We have the XBOM transformation license do we need to install the MPMLink module to use the BOM transformation ?
Fadel
23-Emerald I
(To:AP_10483126)
What version you are using I checked on 2 VMs there are only below licenses :
Fede
AP_10483126
(To:Fadel)
It is version 13.0.2. So does this mean to use Bom transformation the MPMLink module is not required to be installed ?
Fadel
23-Emerald I
(To:AP_10483126)
Without MPM there will  be no BOM transformer available
Fede
As mentioned by Fadel, the MPMLink module is needed primarily for BOM transformation using the BOM transformer. Also, the module enables for Mfg. Process planning. For, transformation you will require the BOM transformation license. For creating process plans and other Mfg objects MPMLink module license will be needed.
Hope this helps.
regards
~Syed
