how to add the folder "D:\Program Files\PTC\Creo 3.0\Common Files\protoolkit\" to Exception Site List in Java Control Panel?
java 1.8.x
windows 7 x64
internet explorer 11
on the Java web site, there are only exsamples for HTTP and HTTPS,
there is NOT any exsample for FILE protocol.
file:///D:\Program Files\PTC\Creo 3.0\Common Files\protoolkit\
file:///D:/Program Files/PTC/Creo 3.0/Common Files/protoolkit/
neither works
as a result , when i open the ProToolKit API , there comes the java security warning message.
We changed mostly to the non Java Version of the Helpfiles.
file:///<INSTALL_PATH>/Creo%203.0/M100/Common%20Files/protoolkit/protkdoc/manual0/loadToolkitDoc.html
So it's not that easy to make searches, but it works very well to find commands if you have an idea of the command name.
Br,
Eike
Here is an example of my Pro/TOOLKIT exceptions list.
You must use forward slashes in the path. I see that you have that in one of your examples. However, it seems you are missing an additional path/file.
file:///C:/PTC/PROE_WF5_M200/protoolkit/protkdoc/
thanks so much for your reply.
1, I notice that , there is no SPACE in you path. I guess that the SPACE in the path have some affect.
i tried replace the SPACE with '%20', and i will try to copy the doc files to a folder with no SPACE.
2, there are 3 '/' after "file", is it right?
3, do i need to add both 2 locations in your picture to the Exception Site List?
file:///C:/PTC/PROE_WF5_M200/protoolkit/protkdoc/NSCPTestSwing.html
4, i encountered a policy problem, i will upload the screen snap later.
hi pwilliams-3
i tried again, it seem there is no relation with the SPACE.
file:///D:/Program Files/PTC/Creo 3.0/F000/Common Files/protoolkit/protkdoc/
it works.
however, there is another problem.
AccessControlException
access denied ("java.io.FilePermission" "\D:\Program Files\PTC\Creo 3.0\F000\Common Files\protoolkit\protkdoc\images\PTCLOGO\ptclogo.gif" "read")
detail message is as follows
CacheEntry[file:/D:/Program%20Files/PTC/Creo%203.0/F000/Common%20Files/protoolkit/protkdoc/APIWizardStartup.jar]: updateAvailable=false,lastModified=Fri May 27 16:17:39 CST 2016,length=2459
# Swing Found.
CacheEntry[file:/D:/Program%20Files/PTC/Creo%203.0/F000/Common%20Files/protoolkit/protkdoc/APIWizardUI.jar]: updateAvailable=false,lastModified=Fri May 27 16:17:39 CST 2016,length=91030
Reseting Vectors
Error dfdasfdsfdsfsd:java.security.AccessControlException: access denied ("java.io.FilePermission" "D:\Program Files\PTC\Creo 3.0\F000\Common Files\protoolkit\protkdoc\config.TXT" "read")
Error in reading Configuration File
Error dfdasfdsfdsfsd:java.security.AccessControlException: access denied ("java.io.FilePermission" "D:\Program Files\PTC\Creo 3.0\F000\Common Files\protoolkit\protkdoc\msg.TXT" "read")
Error in Reading Message File
Errorjava.security.AccessControlException: access denied ("java.io.FilePermission" "D:\Program Files\PTC\Creo 3.0\F000\Common Files\protoolkit\protkdoc\api.IDX" "read")
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at sun.plugin2.applet.AWTAppletSecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkRead(Unknown Source)
at java.io.File.isDirectory(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(Unknown Source)
at java.net.URL.openStream(Unknown Source)
at API_DataManager.init_readAPITreeFile(API_DataManager.java:300)
at API_DataManager.<init>(API_DataManager.java:249)
at apiwizard.init(apiwizard.java:67)
at com.sun.deploy.uitoolkit.impl.awt.AWTAppletAdapter.init(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Foreground = sun.swing.PrintColorUIResource[r=51,g=51,b=51]
thanks for your further help
This has been answered here:
First of all, thanks very much.
I just can't believe that Creo 3.0 can not work well with java 8.After all, Creo 3.0 is realeased more than a year.
is it possible without Java 1.6?
As java suggest "update the java to the latest version", is it possible with Java 8?
Br,
Eike
i updated to M120 yestoday, and I get it.
Thanks for your warm help.
bty, why not sign the jar?
or is it possible to grant permission through java security?
