Feature Recognition
MukaSingh
Feature Recognition
I am trying to import a step file and would like to use the feature recognition option. I saved the frt_enabled option to "yes" as you can see in my atachment. I'm not sure why the little square icon is infront of the frt_enable command but I still cannot get to the feature recognize option. Can someone help? Thanks
Kevin
(To:MukaSingh)
For options with the computer or box looking icon to take effect you need to exit and restart ProE. Options with a lightning bolt take effect in session. Options with a wand take effect only when new files are created (i.e. work when creating new empty part, does not work using start parts).
MukaSingh
(To:Kevin)
Kevin
I exit ProE and I still do not have access to the Feature recognition Command. The computer looking icon is still infront of the "Frt_enabled" command even after I exit and return to ProE. Do you or anyone else have any idea how to get access to the Feature Recognition command?
Kevin
(To:MukaSingh)
Is the option showing up in the Edit menu and greyed out or is it not showing up at all? It showed up in in the menu after I added the option and restarted ProE. You may need to add the Feature Recognition Tool from Tools>Customize Screen>Toolbars tab. If it's in the menu I think you need to select the geometry first. The icon will remain next to the option, it won't disappear, it's just an indicator of when the option is applied.
