A problem of Double-headed screw
bduncan
Hi all
Here is a 2-dimensional drawings.I try to make it into a three-dimensional,
but unsuccessful,
Anybody have experience on this! Plz help me.
Kevin
(To:bduncan)
Here is a model of the double thread.
29 REPLIES 29
No one ?
highway45
(To:bduncan)
Could you tell us, what your problem is exactly ?
Did you not manage this spiraled loft or are you missing functions for it ?
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
I used with VSS,but unsuccessful.
Kevin
(To:bduncan)
bduncan
(To:Kevin)
This is what I want. Thanks!
Hi Blue_Duncan,
I have a video Tutorial showing one way of modeling the threads. In this toturial, i created a 4X thread Bit. There`s also the Helical function in Proe that may serve its purpose in these kind of situation but i personaly prefer the method illustrated in the video... Here it is: http://www.youtube.com/watch?v=6DdjyF7b8oE
Tell me what you think and good luck.
Kevin
(To:ptc-2559830)
Just tried this method and it works better than the helical sweep. The geometry construction I used tends to cause some slow down when creating the solidify feature.
I should add that the method illustrated in the video creats a kind of distorted cut... just like having a Warp feature doing it instead. The cut is not circular. You can see this effect if you increase the amount of turns.
I can not link to your website.
I can not link to your website.Pass me the video files,please.
blue_duncan@qq.com
I cannot attach the video file in the email because its to big so i posted it on rapidshare. Here`s the video download link... try that:
http://rapidshare.com/files/401276735/Bit_tutorialForMCAD.mp4.html
Its really simple.just click on Autobildz tab in detailing mode.
if your Autobildz tab is not highlighted you need to do some configuration setting
enable_autobildz configuration option.
and see how easy is to create 3D-model from 2D-drawing
I do not know how to do what you said.
Kevin
(To:bduncan)
Here are some more files showing some different ways of creating this.
Does are very good examples. thanks!
bduncan
(To:Kevin)
You are a warmhearted man
bduncan
(To:Kevin)
sd5=7.75*360*trajpar How to get the dimension 7.75 ?
the value 7.75 is arbitrary. It depends on what angle you whant the helical feature to stop at.
For exemple:
for ---7.0 * 360 * trajpar ---
At trajpar = 0 (begining of sweep) the angle reference is zero (7.0 * 360 * 0)
At trajpar = 1 (end of sweep) the angle is still zero (7 * 360 * 0 = 7 full turns, hence zero degree to its original reference)
for ---7.75 * 360 * trajpar ---
At trajpar = 1 (end of sweep) the angle is at 270 degrees (7.75 * 360 * 0 = 7 full turns and 3/4 (270), hence 270 degrees to its original reference)
From what i can assume from Kevin's work is that he wanted the helical sweep to end at a given angle (270 degrees relative to its begining of curve angle)
for some reason i can't put the image directly in this message. I have attached a image illustrating what i'm saying with the exemples
Kevin
(To:bduncan)
Going back to your original drawing there is enough information that the 7.75 isn't completely arbitrary. Removing the shank length the thread length is 279 (I assume mm). Defining the VSS through the ridge of the first thread and using the lead value you specified on your drawing, the ridge distance of the first thread is 48 mm in one revolution. If you you start at the first ridge the thread length is 278 mm. Dividing 248 by 48 gives 5.792 revolutions. Noticing that the thread doesn't go all the way to the end I chose 5.75 as the number of revolutions which is 276 mm in length. Because of the section I used I needed to extend the sketch for the origin trajectory so the cuts extend through the entire length. I chose to extend the trajectory 1 lead length (48 mm, 1 revolution) at each end so the number of revolutions needs to be 7.75 to make the lead for the screw correct. Another way to do this is to replace the 7.75 in the relation by the length of origin trajectory/lead length which should give the same value and you wont have to worry about updating the value manually if you change the length.
bduncan
(To:Kevin)
Kevin
(To:bduncan)
Unfortunately I don't have the software required to make a video. For the first VSS (from the picture it looks like that's the one you are refering to), the one used as the X-trajectory, if you have created the section and entered the relation are you getting a flat surface? If so check the options tab and make sure it is set to variable section. Jaques-Michel shows how to create it in his video. The only other thought I have is is that a construction circle or are you using a cylinder surface as a reference? If the latter, it appears you may have additional geometry (two lines) that is preventing a regenerable section. If the end points are at the center and the other on the circle as you have shown in the picture there should only be an angle dimension (sd3).
bduncan
(To:Kevin)
bduncan
(To:Kevin)
bduncan
(To:Kevin)
Wrong 。The original value is 273.
Kevin
(To:bduncan)
I had to make some assumptions because not all the information you show in your pictures came through. When I initially opened the dwg you posted some information is missing when I import the drawing. Here is what I get. The 273 dimension does not show up. Although I could have gotten the dimension by adding a created dimension I didn't think to try that since there was no indication of scale.
gvora
(To:Kevin)
Kevin,
Could please attach the zipped file again? I could not unzip it. I ge the message that it is part of othe file
Gautam
Kevin
(To:gvora)
I can upload it again but it will be a couple of days before I can. I did try the files again and had no problems opening them. Another thing you may want to try in the meantime is select the file, right click, and choose explore. This should open the zip file in windows explorer and you should be able to extract the files that way.
Kevin
(To:gvora)
Here is a new upload to see if you can open.
bduncan
(To:Kevin)
How do I contact you? Can you tell your contact details? Such as MSN account?
