I'm tring to add a 40 deg draft around extruded text. I was able to add a 30 deg draft by picking all the side surfaces of the extruded text, but it won't let me increase the draft to 40 deg. I found a tip on the user group to add a datum planat an angleand use the datum as the hinge planethen control the addtional draft with the datum. This seems to work with a single surface, butnot with multiple surfaces.
Any help would be greatly appreciated.
Thanks Steve
