Assy Status - Creo 2
davehaigh
In Creo 2 I removed some features in the model that were used as placement references for assembly components.
The Status column in the model tree of the assembly still says Regenerated, until I regenerate the assembly, then the status for those items with the missing reference will change to Frozen.
I don't recall this being necessary in WF4. I thought it just changed to Frozen automatically without a regen.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
1 REPLY 1
RandyJones
20-Turquoise
(To:davehaigh)
> components.
> without a regen.
Do you have config.pro variable comp_instance_fail_act set to freeze?
comp_instance_fail_act freeze
> David Haigh
> Phone: 925-424-3931
> Fax: 925-423-7496
> Livermore, CA 94550
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
