BOM Table Question, WF4
JeffHoracek
2-Explorer
All,
We've created a new BOM table which we've rolled out, and I've received some feedback that whenever an item is added to the assembly, the BOM table resorts itself, so what was item #4, may end up now being item #6, what was item #2 is now item #3....
I don't think using the Fix Index option is the only answer, but I very well may be wrong.
Anyone have an idea on what I can change in the table to prevent this or what I missed when the table was originally created. It's no biggie if I need to create the table again.
Appreciate any insights.
Jeff Horacek
Global CAD Administrator/Design Change Coordinator
STERIS Corporation
5900 Heisley Rd.
Mentor, OH 44060
TomU
(To:JeffHoracek)
Take a look at 'Sort Regions'. You add a sort, then pick a row to sort by. In your case it sounds like you need to sort by item number.
[cid:image001.png@01CFB099.56855FE0] [cid:image002.png@01CFB099.56855FE0] [cid:image003.png@01CFB099.56855FE0]
