Hi folks!
I have one issue that I can't solve on my own, perhaps someone could help me with it.
Since I have to use a different balloon text height from the main text height, I manually change it every time creating an assembly drawing. Is there a way to input an exclusive balloon text height in prodetail file? I couldn't find the necessary parameter there.
Please note that I'm talking about the text size, not the min/max balloon radius.
Thanks in advance!
I could not find one in the Creo 7 list of config settings. I don't have a list of the hidden settings.
I would suggest creating a mapkey to perform the text size change.
If these are BOM ballons, you could create a custom BOM ballon with the desired text size.
Thanks a lot, @kdirth !
In my case, the custom symbol solution works perfectly 👍
I have the "normal" and hidden config settings list (I use them so my text editor will show the hidden options I have set with a distinct text color). There is not a hidden option, either, for the setting of balloon text.
