3-Newcomer
November 6, 2023
Balloon Text Size
  • November 6, 2023
  • 2935 views
Hi folks!
I have one issue that I can't solve on my own, perhaps someone could help me with it.
Since I have to use a different balloon text height from the main text height, I manually change it every time creating an assembly drawing. Is there a way to input an exclusive balloon text height in prodetail file? I couldn't find the necessary parameter there.
Please note that I'm talking about the text size, not the min/max balloon radius.
Thanks in advance!
Best answer by kdirth
I could not find one in the Creo 7 list of config settings.  I don't have a list of the hidden settings.
I would suggest creating a mapkey to perform the text size change.
kdirth
kdirth21-Topaz IAnswer
kdirth
If these are BOM ballons, you could create a custom BOM ballon with the desired text size.
3-Newcomer
November 6, 2023
Thanks a lot, @kdirth !
In my case, the custom symbol solution works perfectly 👍
