Basic Dimensions
pauldelong
Basic Dimensions
When we set basic dimensions to dimensions with multiple quantities (i.e. 2x 5.0), the box is only around the dimension value... is there a way, .dtl or config.pro setting, that will automatically place the box around the quantity and value without using the @[2x 5.0@] workaround?
6 REPLIES 6
BenLoosli
(To:pauldelong)
One of the problems is that either method (inside or outside the box) is valid and both are shown in various pictures in ASME Y14.5m.
Thank you,
Ben H. Loosli
USEC, INC.
mlocascio
(To:pauldelong)
Paul DeLong,
You can hire me! I KNOW how to do that! LOL
Seriously? Well, you will need to "fix" the text.
Michael P. Locascio
Paul,
Ben is correct in that both methods are now valid. We had to do two things,
created a mapkey that you can use to place the 5x back inside and also
change or checking policy to state that the face of the drawing can not
have both, either all numbers are in the box or out of the box.
Raytheon
Lance Lie
Sr Computer System
Technologist II
310.616.1551 office
310.426.4968 cell
310-647.0315 fax
Our convention has been, since at least the mid 80's, to use inside and outside the box to indicate the difference between places and spaces.
Places = outside the box
Spaces = inside the box
So you can do this:
4X [3X 6=18]
which means the spacing between the holes is 6 for a total length of 18 and this occurs 4 places on the part.
David Haigh
Can you point to the location in the ISO or ASME standard where this
convention is stated? I've been trying to figure out why pro/e changed this
and so why we should change with it. It would be great if there really was a
convention about inside the box and outside the box.
regards,
Alfonso
I didn't mean to indicate that our convention is a codified standard. It's what we do.
David Haigh
