The message you are trying to access is permanently deleted.
I would like to know if, in CREO Simulate, it is possible to animate any results (not only the von mises stress already animated once the result windows is open) and, in the case, if it is also possible to animate parts cut with capping surface.
Thank you very much for the help!
CC
Yes, you can animate other values, like different components of the stress tensors, displacement components, strain energy, failure index... No, you cannot animate cutting or capping surfaces.
It is possible you are using Simulate LITE which will be missing most of the functionality in a regular simulate license.
Ok thank you very much for the answer!
CC
