Hi there,
I was creating few annotation in creo drawing, so there i want to add custom symbols in my annotation.
I tried to finding where this symbols are saved but i can find it, i found one way but it was for adding pre defined symbols in note (By &sym(symbol name) but that does not work for annotation.
so my question is, how we can add custom symbols in annotation (i.e. in Prefix/Suffix).
The syntax &sym(symbol name) works for drawing annotations.
But you must preload the symbol into the session.
Please see the help page and community answers below
The second way to call a custom symbol is to add it to the special.fnt font.
Then you can call the symbol from the text symbol palette.
Look for the pim_install_guide.pdf file in the Creo distribution and the section 'Customising the Text Symbol Palette for Creo Parametric' in the file.
The option you suggest is for inserting symbols in notes, but for my scenario i want to insert custom symbol in annotation so except &sym(symbol name) [which is used for notes] is there any other option we have to insert custom symbol in annotation
Another option is to use special.fnt.
See the answer above.
special.fnt is a OOTB vector font that contains characters that cannot be entered from the keyboard
You can decompile the fnt-font into a src-file and then modify it. Then compile it back into fnt.
See the 'Font Definition' section in the pim_install_guide.pdf file, which I wrote to you about yesterday.
Unfortunately, editing a vector font in a text editor is very inconvenient.
But I remember there was a third-party GUI utility for this purpose. 'FontViewer FNT' or something like that...
