Hi there,
I was creating few annotation in creo drawing, so there i want to add custom symbols in my annotation.
I tried to finding where this symbols are saved but i can find it, i found one way but it was for adding pre defined symbols in note (By &sym(symbol name) but that does not work for annotation.
so my question is, how we can add custom symbols in annotation (i.e. in Prefix/Suffix).
The syntax &sym(symbol name) works for drawing annotations.
But you must preload the symbol into the session.
Please see the help page and community answers below
The second way to call a custom symbol is to add it to the special.fnt font.
Then you can call the symbol from the text symbol palette.
Look for the pim_install_guide.pdf file in the Creo distribution and the section 'Customising the Text Symbol Palette for Creo Parametric' in the file.
The option you suggest is for inserting symbols in notes, but for my scenario i want to insert custom symbol in annotation so except &sym(symbol name) [which is used for notes] is there any other option we have to insert custom symbol in annotation
Another option is to use special.fnt.
See the answer above.
special.fnt is a OOTB vector font that contains characters that cannot be entered from the keyboard
You can decompile the fnt-font into a src-file and then modify it. Then compile it back into fnt.
See the 'Font Definition' section in the pim_install_guide.pdf file, which I wrote to you about yesterday.
Unfortunately, editing a vector font in a text editor is very inconvenient.
But I remember there was a third-party GUI utility for this purpose. 'FontViewer FNT' or something like that...
Thank you @Van_AG.
Suppose I decompile the special.fnt file — how can I add my custom symbol (saved as a .sym file) into the .src file before compiling it back into a .fnt file?
You cannot add an existing sym file to the font.
You should create a new graphic symbol definition in the src file (a new 'letter' in the font). This definition is a sequence of point coordinates and segments as described in the pim_install_guide instructions.
Which symbol would you like to add?
Please share the image.
Hi @Van_AG thank you for your help so far. The symbol I want to add is a circle split vertically, with the left half filled and the right half empty.
I checked the guide on creating symbols using the 16×16 grid method, but creating symbols this way will be very time-consuming, especially since I have around 30 to 40 symbols. Is there any option to convert my symbol directly into the required ASCII code format?
I will try creating the font and test it on my side. One last request if possible, please share the location where these GIFs are stored and how I can link a specific symbol to its corresponding GIF.
In short, the gif file <creo_loadpoint>\Common Files\text\resource\sp_154.gif contains an image of the symbol with ASCII code 154 from the font.
The location of this image in the Creo symbol palette is determined by a text file that is connected by the custom_text_symbol_palette_file config option.
Please refer to the section Customising the Text Symbol Palette for Creo Parametric in the pim_install_guide.pdf file.
This is the best guide for customising Creo fonts. Seriously. I got all the information from it myself when I needed to customise fonts.
Thank you so much @Van_AG for your support. I will try these options and update you accordingly. If you have anything additional to suggest on this topic, please let me know. Otherwise, I can consider this as a solution, although it is slightly inconvenient to implement.😅
