11-Garnet
December 1, 2025
Can we add custom symbol in drawing annotation
  • December 1, 2025
  • 621 views
Hi there,
I was creating few annotation in creo drawing, so there i want to add custom symbols in my annotation.
I tried to finding where this symbols are saved but i can find it, i found one way but it was for adding pre defined symbols in note (By &sym(symbol name) but that does not work for annotation.
so my question is, how we can add custom symbols in annotation (i.e. in Prefix/Suffix).
Van_AG
The syntax &sym(symbol name) works for drawing annotations.
But you must preload the symbol into the session.
Please see the help page and community answers below
https://support.ptc.com/help/creo/creo_pma/r12/usascii/index.html#page/detail/notes_adding_dsymbols.html
https://community.ptc.com/t5/3D-Part-Assembly-Design/Using-a-Symbol-in-a-drawing-format-table/td-p/377465
The second way to call a custom symbol is to add it to the special.fnt font.
Then you can call the symbol from the text symbol palette.
Look for the pim_install_guide.pdf file in the Creo distribution and the section 'Customising the Text Symbol Palette for Creo Parametric' in the file.
11-Garnet
December 2, 2025
The option you suggest is for inserting symbols in notes, but for my scenario i want to insert custom symbol in annotation so except &sym(symbol name) [which is used for notes] is there any other option we have to insert custom symbol in annotation
Van_AG
Unfortunately, I don't know how to convert sym into a symbol definition for a vector font.
Maybe your ptc reseller could help you with custom special font...
Usually, this only needs to be done once, but yes, I agree, editing a font is a time-consuming.
And you also need to draw a gif for each character so that it is displayed in the character palette
