Cannot Edit Tolerances in Creo Drawing – Tolerance Tab Greyed Out
luiz.hnm
11-Garnet
Hello, I’m having an issue in Creo Drawing:
  • When I select a dimension and go to the Tolerance tab, all options (General, Shaft, Hole) are greyed out/uneditable.
  • I have already enabled tolerances in the model properties.
  • I have already retrieved ISO tolerance tables.
  • The dimension is not a reference or driven dimension.
  • Curiously, some drawings work fine, and their Tolerance tab is fully editable.
Has anyone encountered this? How can I enable the Tolerance tab to edit tolerances in drawing dimensions?
Thank you!
tbraxton
(To:luiz.hnm)
In drawings where you have this issue what is the drawing detail option tol_display set to? The default is no, change it to yes and see if that resolves the issue.
Involute Development, LLC
Consulting Engineers
Thank you for the reply! Unfortunately, it didn’t work.
tbraxton
(To:luiz.hnm)
It is hard to determine root cause without access to a data set with the issue. Are you able to post an example of a model and drawing exhibiting the problem? There are many things that can contribute to this symptom.
I noticed a difference between two dimensions in the same drawing when I open the 'Dimension Text' option. One dimension displays basic symbols like ±, Ø, and radius, while the other shows GD&T symbols such as ST, flatness, and position. Could this be the reason why I can use the Tolerance tab for the first dimension, but it is greyed out and unavailable for the second dimension?
pausob
(To:luiz.hnm)
Maybe also try to update-all the drawing.  read this through the discussion in this link for the procedure (backup first!)
