Change Simplified Rep for Already Drawn Views
aderosa
7-Bedrock
Hi guys.
I have a quick question about simplified reps in drawings. I know you can change the simplified representation for new views in the drawing models sidebar, but I need to know if there is a way to change the representation for already created views. I have a part that was drawn as the master rep, but for a long list of reasons, that iteration of the part is now a simplified representation. Is there a way to keep the drawing the same? In other words, can I change all those views from the master rep, to a simplified rep without deleting and redrawing them all?
Best Regards,
Alex
psobejko
(To:aderosa)
I know your situation well, and I even posted a product idea about it.
I discovered there were others before me that did the same thing.
Now I think these product ideas will be tagged as "current functionality", because it is implemented in Creo 4.0
yep -
Redefine a master rep general view and convert it in a simplified rep view for a PART drawing
And for us still in Creo 2 or 3, we're out of luck...
7 REPLIES 7
psobejko
(To:aderosa)
yep -
Your suggestion is better than starting over; I'll give it a shot. Thanks for the idea!
StephenW
(To:aderosa)
Unfortunately, Unless you are on Creo 4 you can not change the rep in a drawing view for a PART.
My course of action on something like this would be to create a new view with the correct rep and use "MOVE TO VIEW" on the drawing items, dimensions, etc.
Not necessarily quick and easy but better than just starting over.
Ahh I see. Well that's unfortunate for me, but it's nice to know they implemented it more recent products.
mender
(To:aderosa)
Depending on what the simpl rep actually does, you might be able to make a family table instance that does the same thing, and replace with that.  But maybe updating to Creo 4 or redoing it is easier.
Patriot_1776
(To:aderosa)
Creo 8:  At least for an assembly dwg, if you create a dwg view of a Simp Rep, the view WILL NOT change if you change that Simp Rep (i.e. add or remove parts).  Will.  Not.  You must delete the view and re-add it.  Having to move BOM ballons, make changes (local sections, etc.) to that new view to match the old view.  Weirdly enough, a BOM inserted using that Rep WILL change.  Go figure...
Patriot_1776
(To:aderosa)
I just had yet another problem with it with my current project.  If you have views on a dwg using a simplified rep and you add items to that simplified rep, THE DWG VIEWS WILL NOT UPDATE!!!  The BOM will, the dwg views will NOT.  This is a BUG!
