Using Creo 10.0.2.0 Commercial license
After I completed a model and associated drawing, we had a small issue. I oriented the model wrong.
I based my sketch in the "Top" plane when I should have based it in the "Front" plane. That would make it line up better in the final assembly. I know it's not a big deal to rotate it in the assembly, but it would be "nice" to just have it fit correctly in the system without rotating.
I figured out I could get the orientation I needed by right-clicking the sketch and selecting references. I then switched Top with Front, Right with Top, then Front with Right to get the actual orientation I needed. Great, the model itself was exactly what I wanted. Unfortunately, as one might expect, this completely broke all of my annotated dimensions.
I tried to reassign the planes for the annotations, but it didn't work.
I then regenerated the original model and tried just switching Top and Front, leaving right alone. I thought maybe if I only swapped those references maybe then I could reassign the annotation planes easily, but it still didn't work.
Like I said it would be "nice" to have the orientation match the assembly. But "nice" is not worth redoing every annotation in the model. Does anyone know a way to have the annotations move along with the sketch when you reassign the sketch reference planes?
Hi @AK_11362522,
Thank you for your question!
Thank you for your participation!
I don't think there is a nice way. Especially if you have a lot of features.
A possible work around that is (sometimes) less work, is to rename your base planes and redefine your coordinate system and your views.
I remember when I was doing some work for a large agricultural manufacturer, they wanted all of the parts to default into place in the assembly. They had a program, that could be used to redefine the part/subassembly to move and reorient the model to meet that requirement. Sadly, I don't have access to that anymore. Not sure if it would accomplish all that you are needing.
I was just able to solve this in a somewhat roundabout way (for my case). If you enter the original sketch where you selected your original sketch planes, you can go up to sketch setup. You can then edit the sketch plane and then sketch orientation, it may be very simple depending on how you need to move it. However, I needed to rotate 90 degrees clockwise about the z-axis, which required me to continue reorienting it (like a Rubik's cube almost) until I reached the desired orientation. You can use the reference plane and then the drop down below it in order to create the correct view. This was done in Creo 10, so this may or may not work on your version, but give it a try!
- Ben
