Compression molding general drawing note
ryan.crisp
Proe Users,
I have a compression molded component that I am creating a production
drawing for and was curious if anyone could share a general drawing note
associated w/ the compression molding process. I have attached an example
note that we use for injection molded components. I don't design many
compression molded components and I'm sure there are some details I would
miss creating one form scratch.
Thank you
Ryan Crisp
Product Development Manager
New Product Innovations
P: 614.410.3964 x164
F: 614-880-2064
www.npi.com
dgallup
(To:ryan.crisp)
I can't help you with compression molding but I have a question about your note #7:
7. INSPECT PART FOR COSMETIC DEFECTS USING THE SOCIETY OF THE PLASTIC INDUSTRY
COSMETIC SPECIFICATIONS OF INJECTION MOLDED PLASTIC PARTS, 1994 EDITION:
ALL TEXTURED SURFACES: GRADE <x> / SURFACE <x>
ALL CAVITY SIDE SURFACES (UNTEXTURED) GRADE <x> / SURFACE <x>
ALL CORE SIDE SURFACES: GRADE <x> / SURFACE <x>
What exactly is the SPI Cosmetic Specification? I went to their website & could not find any standards or specs. There are links to some other organizations like ASTM that they work with to develop standards.
I did get the SPI mold finish plaque years ago & I remember it was like pulling teeth to find it & buy it. They don't seem to want to disseminate their wisdom.
dgallup
(To:ryan.crisp)
Never mind, I found it by googling their site (the internal search turned up nada). You have to go to their store section.
In Reply to David Gallup:
yep,
here is a link that you can use
the spec is $35
