I am using Creo Parametric Release 8.0 and Datecode8.0.0.0
I create counterbored holes using the hole feature in my model. When I create my 2D drawing, I create a hole table. The table will give me the through diameter of the hole, but I can't get it to show the counter bore diameter, or the counter bore depth. How do you add the counter bore diameter and depth?
To insert the counter bore depth and diameter, add a new row, Parameters then enter the parameter name. You can access the feature parameters by right clicking on the feature in the model tree then selecting Parameters.
Hi @BT_12786803
You may try adding hole feature parameters in table using Hole Table > Add > Parameters > Select > Select Feature and add required parameters.
I hope this will help.
Thanks.
Use the parameters for the hole features in custom hole table columns.
Thank you. How are you able to insert the CBORE_DEPTH & CBORE_DIAMETER? Where are you accessing the table in the first picture you shared?
