Counterbored Holes using Hole Table.
BT_12786803
2-Explorer
I am using Creo Parametric Release 8.0 and Datecode8.0.0.0
I create counterbored holes using the hole feature in my model. When I create my 2D drawing, I create a hole table. The table will give me the through diameter of the hole, but I can't get it to show the counter bore diameter, or the counter bore depth. How do you add the counter bore diameter and depth?
mkajdan
(To:BT_12786803)
To insert the counter bore depth and diameter, add a new row, Parameters then enter the parameter name.  You can access the feature parameters by right clicking on the feature in the model tree then selecting Parameters.
Hi @BT_12786803
You may try adding hole feature parameters in table using Hole Table > Add > Parameters > Select > Select Feature and add required parameters.
I hope this will help.
Thanks.
mkajdan
(To:BT_12786803)
Use the parameters for the hole features in custom hole table columns.
Thank you. How are you able to insert the CBORE_DEPTH & CBORE_DIAMETER? Where are you accessing the table in the first picture you shared?
mkajdan
(To:BT_12786803)
