Creo wont allow me to change dimensions in sketcher, When I double click the dimension the action gets overidden and I am prevented from making any changes. It is almost like there are some relations active in the background. I have used dimensional relations before and have deleted them. The problem affects even new part creation, feels like it may even be a setting of some sort.
See this discussion: Solved: Re: Cannot edit dimensions in sketcher any more - PTC Community
And this article: Article - CS378868 - In Creo Parametric Sketcher mode, impossible to enter a dimension by double click, the menu is exited automatically. (ptc.com)
Thanks, It works perfectly!
