Diameter Dimensions
melias-2
3-Newcomer
Diameter Dimensions
When dimensioning a round hole created with the hole command, when I try to dimension the hole it defaults to a radius dimension. Right click the dimension does not have the option of changing it to a diameter. We are doing Model Based Definition using Creo 2.0 Release 090.
Kevin
(To:melias-2)
You need to select the hole edge or surface twice before placing the dimension to get the diameter.
