Display both the finished dimension and the machining dimension
secanto
We need to make a single plane for both the finished dimensions and the machining dimensions, before surface treatment. How can we automatically add a machining value to a dimension? The idea would be to display both the finished dimension and the machining dimension.
6 REPLIES 6
you can create note attached to geometry and put two dimension callouts into it.
Martin Hanák
secanto
(To:MartinHanak)
Thank you but it is only valid for the holes? Another solution for the other functions?
you can create such note for any kind of dimension.
Martin Hanák
secanto
(To:MartinHanak)
And how can I do it automatically for each function?
you have to do it manually.
Martin Hanák
secanto
(To:secanto)
Another solution to do it automatically?
