Drawing Line Scales do not print/export as shown in Drawing Mode
ngoutis
Can anyone explain what controls how Creo scales center, hidden, and phantom lines, when printing or exporting? This is a problem I've ignored longer enough -- hopefully someone can provide some insight for me.
Nick
ngoutis
(To:ngoutis)
Might help if I attach the correct image ....
mbonka
(To:ngoutis)
Hello Nick Goutis,
l´m almost sure that right settings are hidden somewhere in PEN TABLE FILE. *.PNT extension. These file is responsible for 2D drawing to PDF printing output.
Don´t know exact enswer, but can give you some directions:
- see attached file with basic informations about *.PNT file
- see ProE help about PEN TABLE expression
- see PTC community for PEN TABLE expression
Milan
mbonka
(To:mbonka)
Have found some more simplier PDF "manual" about *.PNT file.
Please Refer:Suggested Technique for Creating Table.pnt files and Setting Default Pens
Hope it can explain many question...
Milan
hidden line print pattern can be defined in pen table file:
pen  3  pattern 0.5, 0.2 cm; thickness 0.025 cm; color 0.0 0.0 0.0;  half_tone_color
axis print pattern depends on drawing size, by default, you can configure pattern length using drawing option:
see my reply on Axes printing page
MH
Martin Hanák
