Drawing Template and BOM table
kgwmu
7-Bedrock
I have created a format and a template for creating new drawings. In the format I have created a BOM table with 2D repeat regions, so it automatically populates when an assmebly is added to the drawing. I then created a template that uses that format. The problem I am having is that the BOM table will not populate when I create a new assembly drawing using the template. If I create a new assembly drawing using the format the BOM table populates like it should. In my attempt to figure this problem out, I have tried adding a table to the template separate from the format and I still am not getting the BOM table to populate. Any ideas on what I am doing wrong? Thanks.
kgwmu
7-Bedrock
(To:TomU)
yes, everything was added in the template mode.
8 REPLIES 8
TomU
(To:kgwmu)
Did you have the template in "Template" mode before applying the format to it or manually inserting the BOM?
kgwmu
7-Bedrock
(To:TomU)
TomU
(To:kgwmu)
Does the BOM work correctly if the table is manually added directly to a drawing (with the assembly already present in the drawing)?
TomU
(To:kgwmu)
Forget it. I forgot you already said it worked fine on the format.
What version of Creo are you running? I can do a quick test here....
kgwmu
7-Bedrock
(To:TomU)
I am using creo 2. If you can open them, I will send the files over.
TomU
(To:kgwmu)
Yes, I have WF5, Creo 2, and Creo 3 currently installed. Feel free to PM me if you don't want them public.
kgwmu
7-Bedrock
(To:TomU)
I would attach them here or in a PM but I don't see how to add a file...I only see how to add a link.
TomU
(To:kgwmu)
I just sent a PM to you.
