Drawing repeat region if-statement does nothing
C4DG33K
is it possible to perform a calculation based on an if-statement in a drawing repeat region relation?
Prerequisite:
Model units: mm Kg s
I would like to multiply mdl_pro_mp_mass by 1000 if model parameter mass_unit is set to g instead of kg.
Something like this:
mass_display = mdl_pro_mp_mass
if mass_unit == "g"
mass_display = mdl_pro_mp_mass * 1000
endif
It's only the IF that doesn't work; the calculation works fine if tested separately.
It works in a Post Regeneration relation in the model (using pro_mp_mass instead of mdl_pro_mp_mass), but I would like to not add the relation in the model.
Tested on both Creo 9.0.3.0 and 11.0.6.0
Any suggestions?
Thanks in advance! 🖖
Voronov
(To:C4DG33K)
Hi
If I understand what you want correctly, try this.
IF MASS_UNIT == "g"
mass=MDL_GENERIC_PRO_MP_MASS*1000
ELSE
ENDIF
For automatic g/kg switching, I use this
IF mass != 0
  IF mass < 0.1
  massg = MDL_GENERIC_PRO_MP_MASS * 1000
    IF massg < 1
    massg2 = massg * 100
    mass = "0." + rtos(massg2) + " g"
   ELSE
    mass= rtos(massg) + " g"
    ENDIF
ELSE
mass = rtos(MDL_GENERIC_PRO_MP_MASS) + " kg"
  ENDIF
ENDIF
6 REPLIES 6
I think you can test parameters mentioned in https://www.youtube.com/watch?v=qiQvnxVwUqk video in Creo 11.0.
Note: I have never done such test,
Note: I got the link when I asked Google ... creo model parameter for units
Martin Hanák
This Creo Parametric 11.0 tutorial shows how your model's units are now available as parameters, which can be designated to Windchill and used in 3D Annotations. When you change your model's unit system, the parameters automatically update. For more information, visit ...
Hi Martin.
That's nifty but not what I'm looking for.
We don't want to change the model units, just choose a different presented unit on the drawing if the model is very small or have a low mass.
Our models span between parts of a gram (small injection molded polymers) to tens of kilograms (casted and/or turned/milled metal) and would like to present the mass accordingly.
Thanks for the suggestion, will look at it when we update to Creo 11!
@C4DG33K wrote:
Hi Martin.
after little Google searching I found following link
https://community.ptc.com/t5/3D-Part-Assembly-Design/Reporting-Model-Unit-Information-in-a-Repeat-Region/td-p/447126
Unfortunately this solution requires modification of existing models.
Martin Hanák
Voronov
(To:C4DG33K)
Hi
IF MASS_UNIT == "g"
ELSE
ENDIF
IF mass != 0
  IF mass < 0.1
    IF massg < 1
   ELSE
    ENDIF
ELSE
  ENDIF
ENDIF
C4DG33K
(To:Voronov)
Thanks Voronov,
I got it to work with just minor changes to your relation.
I want to use MDL_PRO_MP_MASS instead of the GENERIC.
The weird thing is that I initially started exactly as your first suggestion, but it didn't work.
Now when I pasted your suggestion it worked... Inscrutable are the ways of Creo! 😜
🖖 /C4DG33K
RPN
(To:C4DG33K)
If you read this Repeat Region Relation  , it may help you, but it looks like to have both values in the table, maybe you can hide one column.
Note: Check to display with units, because this is just a unit issue!
